Incorrect status after restart - Zigbee contact sensor
Mathmock
Hello,
I have a Zigbee contact sensor connected to a Matter bridge.
Whenever the Matter hub is restarted, the contact sensor appears as open, even though there has been no physical action.
In the Tuya app, it appears correctly, but if I access it through Matter, it shows up as open.
This is only resolved when I physically open and close the sensor.
Virtual ID Contact Sensor: ebc2463465d73246caha0q
ID VirtualHub Zigbee Matter: eba6ffcbd9c94db8be2dxl
zhicheng
Re: Incorrect status after restart - Zigbee contact sensor
Hello, could you please confirm whether this issue (where the contact sensor is physically closed but shows as open on third-party platforms) only occurs when the Matter hub restarts? Or does the status of this contact sensor displayed on third-party platforms such as Apple Home always contradict its actual physical state?
Mathmock
Extremely, after restarting the HUB it is exposed to other platforms with open status
zhicheng
Hello, thank you for your feedback.
We notice that your gateway is currently offline. To further troubleshoot the issue, please bring the gateway back online so that we can retrieve the complete runtime logs. Meanwhile, to accurately analyze the problem where the Zigbee contact sensor shows an incorrect status after gateway reboot, we would appreciate it if you could reproduce the issue a few times (for example, by manually restarting the gateway and observing the sensor status changes). This will help us capture key diagnostic data, allowing us to identify the root cause faster and provide a solution.
Thank you for your understanding and cooperation.
