Aqara U200 Smart Lock
Sugar
Virtual ID of the lock: bf852eopzctzewqc
Virtual ID of the Moe's Hub: bfdd385cadc34fdb76jlx7
Battery status is all the time 0 percent, and door lock status is abnormal, plus you can't open it or close it.
This lock is connected to the Moes hub by the thread network, and then I shared it to the Aqara Matter controller.
Thank you if it can be fixed :)
Sugar
Re: Aqara U200 Smart Lock
Update:
Battery status and door lock status is correct now, but it's still not possible to open or close the lock.
fangping.guo
Hello, can you normally lock and unlock doors using the Tuya app? Are you currently pairing the door lock with the Tuya Moes gateway, then sharing the Tuya Moes gateway with the Aqara gateway? Which app are you currently using to control the door lock?
Sugar
fangping.guo 2025年 Dec 2日 11:39
Hi.
yes it's paired with Moe's gateway then shared to the aqara hub with matter, I can open and lock it with tuya app without problem but only this, battery level is not showing in Tuya app, I use tuya app for automations with this lock, I can control this lock with aqara app over Bluetooth if I'm close to the lock.
fangping.guo
Hello, could you please restart the gateway and then try switching the door lock on and off again in both the Tuya app and the Aqara app? Please let me know the exact times of these actions so I can analyze the logs.
Sugar
fangping.guo 2025年 Dec 2日 14:20
I just did it now.
zimo_liang
hi,Sugar
This issue is due to the need to add TimedRequest to the Matter door lock control. This problem will be resolved in version 1.14.x; please wait for this version upgrade.
Sugar
zimo_liang 2025年 Dec 8日 14:50
hi,Sugar
Understand.
