【开发资料】设备离线提醒功能开发
zerozheng
用途
当设备离线超过30分钟时(低功耗设备8个小时),手机推送中心 和 app消息中心 都将收到离线提醒的消息。
接入
要求:需要接入UI业务包5.8.0及以上版本
source 'https://github.com/tuya/tuya-pod-specs.git'
platform :ios, '11.0'
target 'Your_Project_Name' do
    pod "ThingSmartBusinessExtensionKit"
end
API 说明
  1. 判断设备是否支持离线提醒功能
入参类型说明
deviceIdstring设备id
successblock成功回调
failureblock失败回调
/// get the offline reminder support status of device
/// - Parameters:
///   - deviceId: the id of the device
///   - success: support if status is true, otherwise not support
///   - failure: error happen
class func getOfflineReminderSupportStatus( withDeviceId deviceId: String, success: @escaping (Bool) -> Void, failure: @escaping (Error) -> Void)
  1. 获取设备当前的离线提醒状态
入参类型说明
deviceIdstring设备id
successblock成功回调
failureblock失败回调
/// get the offline reminder status of device
/// - Parameters:
///   - success: open if status is true, otherwise close
class func getOfflineReminderStatus(withDeviceId deviceId: String,  success: @escaping (Bool) -> Void, failure: @escaping (Error) -> Void)
  1. 更新设备的离线提醒状态
入参类型说明
deviceIdstring设备id
statusbool打开为true,关闭为false
successblock成功回调
failureblock失败回调
/// update the offline reminder status of device
/// - Parameters:
///   - status: the offline reminder status
///   - success: update success
class func updateOfflineReminderStatus(withDeviceId deviceId: String, status: Bool, success: @escaping () -> Void, failure: @escaping (Error) -> Void)
使用示例
class DeviceOfflineReminderVC: UIViewController {
    var deviceId: String
    lazy var label: UILabel = {
        let label = UILabel(frame: CGRect(x: 0, y: 0, width: 0, height: 0))
        label.textColor = UIColor.green
        return label
    lazy var statusSwitch: UISwitch = {
        let statusSwitch = UISwitch(frame: CGRectZero)
        statusSwitch.addTarget(self, action: #selector(change(sender:)), for: .valueChanged)
        return statusSwitch
    init(deviceId: String) {
        self.deviceId = deviceId
        super.init(nibName: nil, bundle: nil)
    required init?(coder: NSCoder) {
        fatalError("init(coder:) has not been implemented")
    override func viewDidLoad() {
        super.viewDidLoad()
        self.view.addSubview(self.label)
        self.view.addSubview(self.statusSwitch)
        self.label.frame = CGRect(x: 20, y: 100, width: 150, height: 27)
        self.statusSwitch.frame = CGRect(x: 170, y: 100, width: 0, height: 0)
        self.statusSwitch.isHidden = true
        self.loadData()
    func loadData() {
        SVProgressHUD.show()
        ThingDeviceOfflineReminderManager.getOfflineReminderSupportStatus(withDeviceId: self.deviceId) { support in
            if (support) {
                ThingDeviceOfflineReminderManager.getOfflineReminderStatus(withDeviceId: self.deviceId) { status in
                    SVProgressHUD.dismiss()
                    self.label.text = "支持"
                    self.statusSwitch.isHidden = false
                    self.statusSwitch.isOn = status
                } failure: { e in
                    self.statusSwitch.isOn = false
            }else{
                self.label.text = "不支持"
        } failure: { e in
    @objc func change(sender: UISwitch) {
        ThingDeviceOfflineReminderManager.updateOfflineReminderStatus(withDeviceId: self.deviceId, status: sender.isOn) {
        } failure: { e in
demo下载地址:https://github.com/tuya/tuya-home-ios-sdk-sample-swift
