ZigBee Smart Knob Switch to Home Assistant Matter
ASk
Please add this device to home assistant matter.
MOES Tuya ZigBee Smart Knob Switch Wireless Scene Button Controller
Product Name: 旋钮开关 (Knob switch)
Device ID: bfe0c46b487de73adenfnu
Product Category: wxkg
thank you
qiusui
Re: ZigBee Smart Knob Switch to Home Assistant Matter
Hi,
I have updated the configuration of this device. (dp1、 dp10)
Please remove it and reconfigure it to see if there is any update.
ASk
Thank you!
It appeared even without removing.
But unfortunatelly it not shows all states correctly
Diagnostic "Current switch position" shows 0 always.
Event "Button" displays
"Pressed once" - after single or double press
"Released after being held down" - ather holding button two events fired, afrer releasing there no events
And I can't add automation or scene for this device - only "1SceneSwitch Current switch position" entity available
I removed the switch with clearing data from Tuya Smart.
Some time it works in Home Assistant until disappeared )
Then I reconnected it and Device ID changed:
Product Name: 旋钮开关
Device ID: bfbb3ba573b105bef1uu8h
But behavior in HA Matter the same.
In Device Debugging I can see such info:
Standard Instruction Set
mode Enum
"range": [
"remote_control",
"wireless_switch"
Standard Status Set
switch_mode1 Enum
"range": [
"click",
"double_click",
"press"
battery_percentage Integer
"unit": "%",
"min": 0,
"max": 100,
"scale": 0,
"step": 1
mode Enum
"range": [
"remote_control",
"wireless_switch"
knob_switch_mode_1 Enum
"range": [
"clockwise_rotation",
"anticlockwise_rotation"
and events in log
Switch 1 single click
Switch 1 double click
Switch 1 long press
knob switch Clockwise rotation
knob switch Anticlockwise rotation
after tripple click
mode wireless switch
mode remote dimming
qiusui
At present, all I can do is configure this only configured the switch 1 and battery power.
