Smartthings no devices
neozzang78@gmail.com
Hello. I have a Moes matter hub.
Trying to use in Smartthings, it can be added correctly to Smartthings but not devices showed. If I add a completely new device it appears in the Moes hub connected in smartthings and works fine. but never shows the others zigbee devices. And if I delete a device in smartlife life and add again, it is not showed in Smartthings .
Moes matter hub
Sub device
fangping.guo
Re: Smartthings no devices
Hello, I have added the device profile and gateway upgrade whitelist. Please upgrade the gateway and try again.
Hello.
I have removed device and add it again.
But I can not find device any platform (smartlife, tuya and smartthings)
I have try several times and factory reset
What should I do brother?
Should I have just upgraded it without deleting the device?
Please help me.
I can not use any device even though at smarlife app.
fangping.guo
“I can not use any device even though at smarlife app.” This issue is unrelated to bridging. You may contact the device manufacturer directly.
