TS0601 does not work with SmartThings.
ydy8103
Hello, excuse me
I added the TS0601 occupancy sensor to the Moes Matter Hub through the SmartLife app,
but it is not syncing (linking) with SmartThings.
Please help me with the synchronization (linking). Thank you
您好,打扰一下 我通过 SmartLife 应用将 TS0601 占用传感器添加到 Moes Matter 网关,
但它无法与 SmartThings 同步(联动)。
请协助我完成同步(联动)。谢谢您!
Matter hub: Moes matter gateway(v1.13.10)
Device Virtual Id: ebf3af9f398a5a374880aj
Model: TS0601
Finger print: _TZE204_sxm7l9xa
Device Virtual Id: ebe075aa330a4d32a9xffa
Model: TS0601
Finger print: _TZE204_ijxvkhd0
Device Virtual Id: eb158ab725838739edbx95
Model: TS0601
Device Virtual Id: ebc6aa7595fe42799fe1qj
Model: TS0601
Device Virtual Id: ebbf6277a3933b922douxv
Model: TS0601
Device Virtual Id: ebdab92ed34303c70eak0f
ㅡㅡㅡㅡㅡㅡㅡㅡㅡㅡㅡㅡㅡㅡㅡㅡ
I have an additional question.
When a device registered in the SmartLife (Tuya) app is deleted and re-registered, the Virtual ID changes.
Assuming that the device I requested for registration is successfully connected to SmartThings and the Matter bridge,
if I later delete and re-register this device in the SmartLife (Tuya) app,
will I need to submit the new Virtual ID and Fingerprint again and request SmartThings integration once more, as I did this time?
我还有一个问题想请教。
在 SmartLife(涂鸦)应用中注册的设备如果删除后重新添加,虚拟 ID 会发生变化。
假设我这次申请注册的设备已经顺利与 SmartThings 和 Matter 网关正常联动,
那么日后如果我在 SmartLife(涂鸦)应用中再次删除并重新添加该设备,
是否需要像这次一样 重新提交新的虚拟 ID 和指纹,并再次申请 SmartThings 联动?
fangping.guo
Re: TS0601 does not work with SmartThings.
Hello, I have updated the configuration file for the device you provided. Please try restarting the gateway or unpairing the device for testing.
Regarding your question, changes to the device's virtual ID will not necessitate reconfiguring the profile. This is because our configuration files reside at a higher level, such as the product ID level.
ydy8103
xiexienin
