Tapo Smart Temperature & Humidity Sensors
Sugar
Virtual ID of Moes Hub is: bfdd385cadc34fdb76jlx7
Tapo T310 Temperature Sensor:
Virtual ID for T310 (Temperature) is bfb5cf5519cd2571f3h5yc
You can't add those child devices to the main screen or change the name.
It is dp_temperature instead of just Temperature.
Tapo T315 Temperature Sensor:
Virtual ID for T315 (Temperature) is: bf649b287424409932xcbr
That sensor is wrongly named; it should be Tapo T315 Temperature instead of T310. T310 is a different version of their temperature and humidity sensor (version without a screen).
Tapo 315 Humidity Sensor:
Virtual ID for T315 (Humidity) is: bf735ce333eac34bc64pqz
That sensor is wrongly named; it should be Tapo T315 Humidity instead of Matter product 2.
Tapo T310 Humidity Sensor:
Virtual ID for T310 (Humidity) is: bffebcbc4ed71e3dc82jw6
That sensor is wrongly named; it should be Tapo T310 Humidity instead of Matter product 3.
Thank you if possible to fix it :)
fangping.guo
Re: Tapo Smart Temperature & Humidity Sensors
Regarding the issue of the device name displayed after it is added to the doodle, as well as the problem of not being able to display it on the main interface, you can provide feedback through the app.
This section of this forum is used to provide feedback on Matter and Matter-Bridging issues.
For example, if your device displays and functions normally within the Tuya Smart app but cannot be bridged, or if it displays or operates abnormally on other Matter platforms after bridging, you can report the issue here.
Sugar
fangping.guo 2025年 Nov 25日 14:09
So, what I have done currently. Firstly, I bought the Zemismart hub and the Moes hub, then I realised that both hubs are exactly the same, same hardware and firmware. If I checked correctly, the hardware and firmware are made by Tuya.
I contacted support through tuya/smartlife app. They told me because it's matter devices, I have to contact the hubs makers. I sent an email to both hub makers. Zemismart didn't help, just a basic automated answer.
Moes support said to send them videos, plus screenshots and a video with log numbers, and they will contact Tuya. No answer for days Moe's.
Update: they said that these devices are not tuya devices so I should contact these 3rd party devices makers hah, which is ridiculous because as matter controller all above issues are on the side of the tuya app and matter controller hub, 3rd party devices makers can't fix this issues, it's not possible.
So basically, who is responsible for the firmware for all these hubs? No one is trying to fix these visual Tuya app bugs for the Matter Controller, plus missing translations for some things. Is there any section somewhere for the matter controller, then?
All these Zemismart, Moes and Avatto Matter hubs are advertised as matter controllers for the Tuya app/platform.
Thank you.
fangping.guo
Hello, I've confirmed internally that the Tuya app currently imposes restrictions on devices bridged in from other brands' Matter gateways, such as limitations on renaming.
Was your device added directly to the Tuya app by scanning a QR code, or was it first bound to another brand's gateway and then added to the Tuya ecosystem by sharing the gateway? If it's the latter, we've logged this restriction issue and are currently working on a solution.
Sugar
fangping.guo 2025年 Dec 3日 10:04
Hello and thank you.
It's how it was added, so firstly Tapo h100 hub added to original tapo app (it's not matter integration), then added to tuya app with matter code, it's 2 weeks old video:
here video when I added tapo h100 matter bridge first to aqara, then QR code taken from aqara app:
in both situations it's the same result
thanks for checking
