Devices are not exported to Home Assistant as Matter
JorgeFrancisco
Today I will test the two dimmers that you adjusted.
qiusui
Re: Devices are not exported to Home Assistant as Matter
JorgeFrancisco 2025年 May 28日 20:58
I changed the hub and the sensors continued with the value of 20%, today they appeared with the value of 100%.
Allright, I will try to reduce the battery value by five times.
After receiving the message, please remove the device from the gateway and then configure the rear bridge to matter.
JorgeFrancisco
Hi! You don't need to change anything else, it is already displaying the correct value, which is 100%. You can leave it multiplying by 5.
qiusui
JorgeFrancisco 2025年 May 29日 16:57
I don't quite understand your meaning. When I replied last time, I had already completed the modification.
I suggest that you can retest it and then tell me the latest data situation so that I can make corresponding adjustments.
JorgeFrancisco
Unfortunately, the sensors continue to have the wrong value of 20%, and should have the value of 100%. Could you go back to the adjustment by multiplying the value by 5 again?
